290
Loser of Keys
211 (M) Ignition PIP signal was erratic or missing - Ignition Systems
214 (M) Error in Cylinder ID (CID) circuit or signal - Ignition Systems
Pulled these codes after i got home from work.
On my way to work this morning i was passing a car and got the engine up to 7k and my check engine light came on. I let the engine return to idle and it went off. So i did this a couple times and the same thing happened, engine gets up to 7k, CEL comes on, get off the gas and it goes off again. I just did a front 60k, replaced the crank sensor but not the cam sensor. Anyone have an idea on whats going on? Im ordering a cam sensor right after i post this.
