Code Scanner/Readers
Tom Higginbotham
I've been reading the forums for a few weeks and noticed a lot of the messages relate to pulling/reading the codes.
I was wondering what a good reader would be and around how much $$$ it costs...
Thanks!
Tom
PROPHET
Well-Known Member
Tonytown, Texas.
The only reader you need is a paper clip, turn ignition on but not to the point the engine starts and watch your check engine light flash...you count the flashes, lets say it flashes 3 then stops then 5 flashes then 6 flashes, your code would be 356, then wait for more codes if you happen to have more than one comung up.
Gen ones have a two digit code and gen twos have a three digit code.
You can find this procedure at www.shotimes.com
boggs3010
MESA,AZ
ok I looked at the :confused: pages...no luck. Could some one hold my hand and give me a direct link?
Hack
Washington State
SinisterSHO
Rust free
630, IL
I've never had good luck with doing the self test thing, I would always be writing down the numbers and it would start flashing again. Seeing that my buddy is a mechanic, if I ever really need to run codes, I ask him to bring his snap-on scanner home which does more than just give codes.
twr
whoohoo
half-way there, I think.
MelectroK said:
If your under the hood triggering the pins, how do you see the CEL?
Umm.. You jumper the pins with the car off, then get in the car turn the key on and watch. After the KOEO finishes, start the car for the KOER test.
