code 511
xpnsiv93
Corrupt state, IL
i just pulled the codes off my car...this is the main one....
511 - No power to PCM pin 1 or bad PCM (processor)
:confused: What does that mean?? :confused:
and then the stored codes were all weird...i had a 115..cant find a listing for that..213 - Ignition SPOUT or SAW circuit open or shorted...how do i fix that one..it was actually a 219 but referrs to 213 for solution...
56 - Vane Air Flow (VAF) or Mass Air Flow (MAF) sensor high (Running) Transmission Oil Temperature sensor too high...that was the last stored one...RESOLUTIONS ANYONE...PLEASE!!!!!
key on engine on.... 116 ....cant find a meaning for that one :rant:
xpnsiv93
Corrupt state, IL
Help People
C'mon people...theres gotta be someone who knows the poor mans meaning on these codes....i dont know what a bad PCM 1 means or any of those other codes....i can take it apart and rebuild it...but i cant decode the computer for it to actually tell me whats WRONG....
Diameg
Ontario, Canada
I haven't had time to check the other codes and come up with any relevant meanings for them but the 511 code is likely due to your LPM.
Take the LPM out and do the test again. I believe you will always get the 511 code when you have an LPM and it's just a result of the computer acknowledging the foreign object.
xpnsiv93
Corrupt state, IL
THANK YOU!!!...VERY MUCH!!!!
I got the meaning for 116..engine coolant temp. sensor out of range- does that basically mean a bad ECT sensor??..and im not quite sure what 56 ACTUALLY MEANS as far as MAF vane off or temp. coolant sensor, do i have one even if im an MTX???...thank you again!!
projectSHO89
SHOless In St L
See my signature for a head start.
Steve
PS. That 2-digit code is invalid for your car, you shoulld only have 3-digit codes.
xpnsiv93
Corrupt state, IL
Steve
PROJECT>>> i thought the 2 digit code was a lil weird also, but it spit out #'s QUICK and i've tried breaking it down the best I could w/the #'s and the #'s end w/a 2 digit..maybe i'll try again tomorrow.....see what she spits out w/the LPM removed...THANX :thumb:
