Cobra bracket mod for 11.5 inch rotors - need pictures
zak
east of Hartford
Bob I have them on an old computer hard drive at home, would need to get the computer hooked up and running over the weekend, if someone has handy please post. From memory 0.7 inches directly upward on both sides (center to center).
kevinspann
Don't take my advice.
Richmond VA
0.7" up, but then the bracket needs to be milled flat and spacers or washers need to be used. This is because the location of the new holes is not an entirely flat area on the bracket.
Baer used to sell (and maybe still does) brackets modified for 12" rotors (you would use redrilled or slotted Crown Victoria rotors). They also came with a spacer and were $74 each when I asked a few years ago.
kevinspann
Richmond VA
Baer12PBRBrackets 002
This is the Baer modified brackets for a 12" rotor, the only difference is you'd want to drill the holes up a bit higher in the bracket for an 11.6".
313tiger
