Clutch
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I had a SHOShop competion clutch installed in my car about a month ago. Ever since I got it sounds like 2 peices of rubber are being rubbed when I go from a dead stop. It was installed by my local Ford (never going back they dont know how much oil my car takes). Is this sound due to my shifting or is normal for a new clutch (it doesnt occur all of the time). Also when the clutch is not engaged and my car is idling, I hear a sound like a worn baseball card in a bike (very soft sound). I know its the clutch because when I engage it, it goes away. Agai n is this normal at all? Im considering having it taken back a second time (they already took it apart to inspect it due to other issues) and reinstalled. Any help would be apreciated.
92 White SHO
HiRevs Competion Clutch
SHOSHOP Engine Mounts
Koni Shocks
StrutTower Braces
UD Pullies
Awesome Sound System
philw349
PhilW
Tucson, AZ
That sound I believe is the throwout bearing (kind of a whirring/ticking sound?). It may be normal depending on how loud it is.
SHOTIME
Giver of life
Boston Ma.
You shouldnt hear a stock TOB..
The rubber sounds might be a loose subframe.
I say take it back. There gonna get ****** (it being the second time) so be ready for it
Eric
mailto:[email protected][email protected]</A>
My Web Space
New England SHO SPecialists
LOUDSHO92
Sponsoring Vendor
Okay educate me on this what relation does the subframe have to the clutch?
92 White SHO
Koni Shocks
StrutTower Braces
UD Pullies
drivinhard
Gainesville, GA
"Ever since I got it sounds like 2 peices of rubber are being rubbed when I go from a dead stop"
When you are releasing in 1st gear? I'm going to guess it's the friction material on the disc. Did the dealer resurface the flywheel?
I have a higher friction disc in my 89 and it's noticably louder than stock...
"Also when the clutch is not engaged and my car is idling, I hear a sound like a worn baseball card in a bike (very soft sound). I know its the clutch because when I engage it, it goes away"
Thats TOB...
White 92
SR71SHO - racer '89
9
94ShoOff
Guest
LoudSho, I believe that you have to drop the subframe in order to replace the clutch.
1fastsho
Athens Ga
Which disk? Is it the dual diaghram clutch or the metal puck disk type? The dual diaphragm clutches Always break the pin holding the throwout bearing to the fork. It is just plastic after all
Shawn Pasley
Innovative Performance Technologies
770-725-4631
www.iptech.tv
92 SHO red/grey
3.2L(bored) Lowered compression(9:1)
stageII cams, Ported/Polished heads,Ported/polished Intake manifold(runners, endtanks, and behind the throttle body), big bore butterflies,80mm maf, LPM,equal length Long Tube Headers and custom Y pipe, Dynomax cat-back, Koni/coil-over suspension, poly-bushings everywhere,26mm FRONT sway bar, 28mm REAR sway bar,rear strut tower brace, solid subframe bushings,subframe connectors, tubular aluminum adjustable rear control arms,shortened shifter,235/45/17 Toyo Proxes T1-S's on TSW VX-1's. 15 lbs of boost here I come!
LOUDSHO92
Sponsoring Vendor
The fly wheel was resurfaced. The clutch material is a higher friction material. Its the SHOShop competion clutch. Otherwise it handles fairly well overall.
92 White SHO
Koni Shocks
StrutTower Braces
UD Pullies
RStalveyARFF
too many shos
Georgetown, MA
that baseball card sound is soooooo TOB. They kinked it installing it. Take it back and give them shit and make them do it all over again. be there when they crack the tranny, if the PP is worn, make them replace that too.
LOUDSHO92
Sponsoring Vendor
I know it seeems like one thing after another. The rubber sound has gone away (maybe my shifting). Only for a short time it sounded like a metal flap or something was hitting something if I went over bump or something. This was like for less then a day. So is it something I sound have checked? Well from what it seems, the clutch was not installed properly (again) and I will try and get it in soon, though time is an issue.
92 White SHO
Koni Shocks
StrutTower Braces
UD Pullies
