Clutch Specs needed!!!!!!!
havier
ct
Does anyone know where i can get the flywheel to crankshaft tourge specs and the pressure plate to flywheel tourqe specs.
RStalveyARFF
too many shos
Georgetown, MA
65 lb ft for the flywheel, 25lb-ft in 2 star pattern stages for the pressure plate. Make sure to use blue loctite on both sets of bolts!
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Isnt there a torque sequence?
I torqued them all like torquing wheel lug nuts. And did it in 2 stages shrug
<small>[ March 21, 2004, 02:42 AM: Message edited by: NotSoSlowSHO ]</small>
revhardSHO
Seattle, WA
two stages on both
flywheel - first is 38lb then 60-65lb
pressure plate - first is 20lb then 24lb
Blue locktite on both sets!!!!
You'll want to cross-tighten the bolts like notslowsho did.
woody32
central, PA
center force dual friction (dont know that part # ) and ram clutches part # ram-88554r (p/n is from summit so it may be a summit only p/n )i never have even seen mentioned in the forums either of these two clutches and was wondering why ? these can't be too awful of clutches,and if we gotta spend $310- 460ish for a clutch for our cars.
i was just wondering,and if there are guys on the forums who have used either of these two clutches,please post about them.
