Bank of SHO
Made some progress today. I now understand the need to have plastic caps for the ball joint boots. headbang Chances are they were already nicked before. The rubber seems rather sad anyway. It rubs right off on my fingers.
The front driver's side subframe bolt looked just fine. The front passenger side bolt was corroded a few inches on the shank, but not the bottom protion of the threads. The rears had the recall performed on them not that long ago. UPS is late, but a new recall kit is on the way. Just how hard is it to replace the front nuts?
To remove the subframe, I placed a jack under the front and jack stands in the rear. The rear was stubborn and didn't want to drop much. I took my time and lowered the front and back a little at a time until...CRASH! The subframe was now separated and on the floor. The power steering rack studs were still sticking through the holes in the subframe. Do you think I damaged the power steering unit when the subframe fell? It was hanging by its hoses and no fluid is yet to be seen leaking. Also there is a rubber hose much like the radiator reservoir *** tube hanging straight down and terminating near the horn. Did something break off of the end of it? What is it?
Tomorrow the tranny gets dropped...well not literally I hope. Any words of advice before I get to it?
