You know, SHOforum sponsor SHOnut Performance has a heavy duty pressure plate that is made to their specifications (reinforced drive straps) by Clutchmasters. Suspect it has some design elements from the old gmorrell pressure plates, I am lucky to have the priveledge to own one of the old gmorrell pp's myself ;-)
The SHOnut peice is NOT a Clutchmasters Stage I, it leaves the pressure plate fulcrum points, that have been problematic for many, alone. It only has reinforced straps and either better rivets or aircraft grade fasteners in place of the rivets. Josh sells the PP with a ceramic TOB so that both weak spots on the pressure plate are taken care of. If you need more holding power I would go for a Clutchnet disc myself (my plan for when my cammed/head worked 3.2 gets built).
