clutch or tranny??
Dr_Thompson
CT
hey guys, got a question. A while back i did a clutch job on my sho and i screwed something up. It drives but the clutch slips horriably. Now the thing im worried about is it grinds in 2nd and sometimes first. When i first drove it i had to get it out my garage and it was low on fluid.I only drove a couple hundred feet and at low speeds but i did notice the grind then.I dont see how this could break the gear. what do u guys think, is the sliping clutch causing the tranny to grind? im gonna get the clutch fixed but i wanna know if its worth taking a look in the tranny while im there.
revhardSHO
Seattle, WA
Check the fluid first. Could be an easy fix.
If its full Im guessing the PP to FW bolts are loose, causing the grinding. A new clutch would be in order.
