clutch issues and noises
greengiant
Holden MA
my 94 mtx makes a weird crack or snap noise something when i push in the clutch, it sounds like its disengaging really rough or something, the clutch pedal is also quite hard are these two separate problems or just one? on the top of the tranni there are a arm that controls the clutch ad its bearing seems to have just about had it, maybe its adding to the problem. I also just in a clutch cable and its fully adjusted but not much difference.
ckinney89sho
fo SHO
NY
it might be a bent fork. Is it going in gear and moving, is it slipping.
