I'm having issues with my 95 SHO climate control. For a couple months now, when I adjust the air temperature it's not regulating it properly. If I start the car and have the temperature set to around 15-20C approximately it will blow cold air, but when I set it beyond that it will only blow hot air. If I max out the temperature and then try to bring it back down to 15C, it will not adjust to a lower temperature and only blow the same hot air. Sometimes if I shut the control unit (EATC) off and let it sit for a bit, then turn it back on to a 15C it will start to blow cold air. Not all the time it will do that though.
Just looking for some recommendations and what to start with.
