clicking noise up front and stalls
havier
ct
i was changing my air filter today and what i think is a computer componet was in the way. It should be screwed in but wasnt for some reason so i moved it over. I start the car and runs fine. I had a small antifreeze leak which i fixed in a minn and go to start the car and i hear a loud clicking noise, the car idles sporaticly then dies. I have no clue whats wrong, please help!
91 Plus
Well-Known Member
Monroe,Michigan
havier:
Did you unplug your maf sensor that hooks to the top of the air box?
Where, exactly, was the "computer componet" and where did you move it? It was likely either the air charge temperature (ACT) sensor on the passenger side of the lower air filter box casing with its red tip or the mass air flow (MAF) sensor on the intake hose above the upper lid of the filter box. Has the CHECK ENGINE light illuminated since the engine started running poorly?
