Clarifying Questions : Wheel Bearing, Knucle, 96 upgrade...
MOSHO92
Modesto, CA / San Jose, CA
I'm in the process of preparing to do the 96 front brake upgrade. There have been many posts on this subject that I have searched which have provided me with a wealth of information. I do, however, still have a few areas I need some more clarification on:
- I have a 92, so I need a new knucle. I have seen the words knuckle, spindle, and hub used interchangeably in many posts. Am I correct to assume that the knucke is the spindle and is the hub?
- When I get this knuckle/spindle/hub will a wheel bearing be an integral part of it, or is it something that is kept from the old assembly.
- Are new knuckle/spindle/hubs availible from Ford or other manufactures? I suppose this is very dependant on what moving pieces are a part of the knuckle/spindle/hub, and whether they have have a tendancy to wear out.
I think that is all for now. I do all the work on my car... I just havn't come across this area yet.
Thank you in advance!
Grifter
New Jersey
The Knuckle/Spindle/Hub are all the same part. I believe that they are called Knuckles on FWD cars and Spindles on RWD cars.
The wheel bearing is part of the knuckles assembly. I would recommend replacing them while you have the knuckles off the car, it makes it much easier.
I had to replace my knuckle recently but I think this is a rare problem, it's considered a non-wear item. You can buy them from Ford but for a price. That's why most people get them from junkyards for less than half the price. oh_sho is parting out a '94, I'm sure you could get the knuckles from him for a great price.
MOSHO92
Thanks! I guess I can work on deciphering the way the wheel bearing presses in/works with the hub when I take it off. I just wanted to be sure I wasn't going to be stranded without a part when it comes to executing the upgrade. (Well, that and I love learning new things :thumb: )
Thanks again, and everyone also please feel free to add or concur.
Hack
Washington State
Assuming you are going to buy "preowned" knuckles (from a wrecking yard) I would highly recommend assembling the whole thing , and have it aligned first. Then, if everything checks out I would disassemble it and have fresh bearings pressed into the hub/knuckle.
I say this because I had new bearings pressed in, assembled everything, and had it aligned just to find that one of the knuckles/hubs was bent pretty badly, making the car almost un-alignable. The only thing that got it close was the fact that my coilovers have built in camber plates. Considering that I spent close to $200 on bearings and the machine shop installing them, I would have much rather swallowed a $60 alignment and a couple hours of my free time.
From what I am told, the bearings will be basically destroyed in the process of pressing them back out again. They may not show any damage, but the internal tolerances will be out of whack.
K-Dawg
Treasure Coast, FL
That's possible, but the chances of a knuckle being bent are pretty low IMO. Also, if the bearings are really shot, you aren't going to be able to align the car anyway.
I got screwed because I didn't realize the knuckles I bought from the JY were non-ABS until I already had the bearings pressed in.
Bizzy
:doh: That sucks!
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Pay special attention to his last 2 lines,,,,that is VERY true. The good part about upgrading a 92 is that you can completely assemble the whole thing on a work bench,,,you know all the parts are there before anything is taken off the car.
Perry
