mastar91169
Good day. I am having an issue removing my crank position sensor. I am working on a 1990 SHO MTX and this particular model uses Phillips Head screws to secure the CKP senor to the engine block(the sensor is located behind the timing belt cover at the crank pulley). I have buggered up the screw heads while trying to remove the screws. There isn't much room to work with here so I was wondering if anyone has any ideas as to how I can get these fasteners out. Any input at all is greatly appreciated!
Thank you.
Thank you.
