Circle Track SHO - KIA
hawkeye18
Sorta cares
Norfolk, VA
Lol I guess I should've specified. I'm actually in Norfolk, VA right now, and will be until october. I will be moving to Lexington Park, MD mid-october. Then I can help you! but if you wanna come down to norfolk... (guess who I work for!)
CircleTrackSHO
Grass Lake, Mi
Some Photos of Damage
92inPA
s.e. PA
Ouch! A couple of the wheel's holes look "egg'd" out. Was the cause of the wreck actually loose lugs, rather than overtightened lugs?
DemonNeno
SHOCAGO Freak
Skokie, IL
You can tell a lot about how a stud breaks in regards to the formation it leaves at the end of the shank on your hub. In your case, with the exception of the one stud center w/ the caliper, it looks like the other 4 were far too tight. Whenever a overtighten lug nut snaps, it will leave a smooth little "hill" on the end of the snap. Weakened studs have a much more of a "jagged mountain" that sticks out, like your stud centered with the caliper. When leaving lugs loose, you will get a vibration, with that vibration, you will beat the stud holes into oblonged shapes on your wheel before they will let loose. (notice it a bit on the pic w/ the steel wheel. Stud hole above the one w/ a lug still on it. notice the shiny edge to the left of the hole). Additionally, the studs will look bent at the tips from undertorquing, as if someone "smeared" the tip across.
This has been my experience and lessons in life. Of course, all this from peepin' at a picture isn't the most accurate, but may help you figure out what really happened. As always, I'm glad as everyone else is that no one was hurt. Looks like that SHO definitely absorbed a high speed wreck rather well, considering it lost a wheel!
hawkeye18
Sorta cares
Norfolk, VA
yeah, seriously, the fascia isn't even cracked! replace the bumper and radiator&support and she'll be fine! ...oh, and you might want a new hub :naughty:
yeah, I'm kidding, but still, I've seen cars in FAR worse shape than that after less severe wrecks. looks like some lugs were too tight, others weren't tight enough. a dangerous combination. Still, it looks like a lot of parts were left unaffected. If you get a good body (wrecked trans/engine), you could probably swap the subframe out and have a perfectly good car. Unless, of course, you warped the subframe in the wreck, but still, that's not a big deal.
CircleTrackSHO
Grass Lake, Mi
what you can't see from the photo was how the right frame wrapped around the bottom of the motor and up into the radiator cavaty.
The sub-frame is a complete loss..
I think I am amending the tread from KIA to On Life Support..
Circle Track SHO: a car barely alive
Gentlemen we can rebuild him
We have the technology
We have the capability to make this car run again
Circle Track SHO will be that car
Better than it was before
Better, Stronger, Faster
http://www.youtube.com/watch?v=woOLEEu8RLI
TimboSHO
Intermediate
Wyoming, MI
Ha ha, nice. The car actually doesn't look that bad after hitting a wall at 80. A healthy donor car would provide all you need. Have that video yet? :biggrin:
poffffd
