qwik huh
I have been fighting a problem in my SHO for quite sometime now and have a few questions about the CID sensor since I have not yet replaced it. The DIS modules is used but off a low milage motor that ran fine, the cam and crank position sensors were installed about 3 years ago and shimmed properly as far as I know. The only thing I have not tried yet is the CID sensor.
The car will develop a random miss when driving. There is no specific time or reasoning but all of a sudden it gets a bad miss and the CE light comes on. The harder you press the gas the more it pops and sputters. If I keep driving usually it will start running fine again in a few minutes. A couple times I have pulled over and turned off the car. When I start it back up I get a CE light and no tach signal and the car runs fine and then after a few minutes the light goes off. The car is also hard to start at random times. I hooked up a scanner but I don;t have the codes with me. I believe one was 852 and something about pip. Anyone have any advice? am I one the right track looking to replace the CID? Is this a reasonably priced part and is it easier to install than the CPS?
I wondered about that once seeing a code out of order before.. (bigger # first)
