CID or Rear Cam Oil Leak, Part #
Best Sho
Hudson Falls, NY
Hi,
My power steering unit is wet with oil. So how do I know if is the CID or rear cam seal?
I just replaced the front/back and front/front cam seals and crank seal.
Does anybody have the CID part # and roughly the price? And what does it do?
Is the cam seal all the hard to replace? I hear it all done by feel.
Smoke coming from up in the area and it smells like oil.
There a playstation game that has the SHo in it, does anybody know the name of the game?
(hint G.T.)
Thanks, Mike
The CID does not have a seal. The rear bank exhaust camshaft uses the same seals as the two intake cams. They are the teh National 1213N or the Fel-pro TCS45870 set of three.
Access to the back seal requires the removal of the CID, CID mounting ring and CID sensor tab. Removal of the seal is tougher because of its recessed position and location adjacent to the strut tower. This makes it much harder to get the old seal out. The access is simpler with the timing belt cover, timing belt and camshaft pulleys removed.
<small>[ June 30, 2003, 03:51 PM: Message edited by: sdpatt ]</small>
SHO_Driver
Montreal, QC
"There a playstation game that has the SHo in it, does anybody know the name of the game?
(hint G.T.)"
Gran Turismo 2. Has a gen III only.
SHO_Driver:
(hint G.T.)"
Say what?
nc89sho
S13 Sellout
Clemmons NC
there is another game that has gen II in it, but i don't know the name.
and ditto on the previouse post obout the seal.
Best Sho
Hudson Falls, NY
OK Thanks,
What would I ask for, for the CID?
I've got Loctite on the bolts for the camshaft pulleys, so will they be hard to break loose?
What movie had Clint Eastwood and a Sho in it?
Thanks, Mike
<small>[ July 01, 2003, 01:27 PM: Message edited by: Best Sho ]</small>
DigDeez
Chicago
Excuse-Moi? for bringing up old shit, but this thread has exactly the same symptoms as my smoking sho. Now, I'm trying to understand something about the seals and the cid in this area. Would I be right in replacing these seals to halt this leakage?
DigDeez
DigDeez
Chicago
I've just read more threads on this matter.....but in my case I think it's P/S fluid leakage in this exact area as there is major P/S fluid leaking profusely in this area. Is there any related seals in this area for P/S fluids. Thanks!!!
ShoBad236
Houston, Tx
qoute: "What movie had Clint Eastwood and a SHO in it?"
Bloodwork.
Best part of the movie, untill the damage. :)
ribeye2065
