SolidState
No Mo SHO
correct my if I am wrong here, guys... (and gals)
I have an oil leak on the right bank near the CID. I have replaced my cam cover seals, so I automatically figured that wasn't the case. My front main seal is leaking a bit, but not enough to cause the burn off I am seeing right now.
The back side of the engine is coated, from the cam cover down, so I pulled the CID off with its 'ring', but found no oil in the CID. So I am guessing that the cam seal is fine, and I am going to have to pull the cam cover...
sound right to you guys? thoughts, comments?
