EHBOY
Hey Guys... i'm changing out (or trying at least) my rear cam seal which is located behind the CID Sensor.(ATX) Here's what i've done so far.
1. Removed crossover tube for access.
2. Unplugged sensor.
3. Removed screws that hold CID to the mounting ring.
4. Removed two small phillips screws to take out the little ring inside.
Now... i'm stuck.
Looking down on that area... there are two 10mm bolts which i've removed. and on the face of that assembly, there are two tiny little bolts which i've removed. What is the next step. The search function hasn't been able to help. and is this CID assembly different on a MTX?
Thanks for the help.
Shaun
Now... i'm stuck.
Shaun
