Check engine light
SHOOFF13
SHOOFF
Massachusetts
Everytime I put the pedal to the floor hard after I am done slowing down from doing it the check engine light shines on then shuts off in about 2 minutes after. Is this possibily the egr valve? Oxgen sensors? or what else? Can somebody help me out. This condition mostly happens during warm weather conditions, also.
Racer X
SHO Pilot, Retired
Connecticut
Check to see what codes are stored so far, but if I had to wager a guess, I'd say O2 sensor. The code will tell you which one.
My SHO did the exact same thing the first night I had it on the way back from RI to NYC. I did I quick top end run coming into CT, and when I started to slow down I got the CEL.
oxrox
Edmonton, Canada
My CEL comes on every morning at the top of the same hill on my way to work....the only code that shows up tells me it is the DPFE sensor....whatever that is.
Ryan
95 ATX
hondas hate me
97Cobra
Greeley
<-----CEL comes on also
My check engine light comes on when iam doing about 75 and when it gets warm and i have new EGR and new 02 sensors, and i took it to autozone to check the codes and he said it said memory failure and he said it might be because of my super chip i have in it. he also said it might be the LPM :frown: :cry: :shrug: and now my air bag light flashes 4 times and then 5 times help me please
Mr Anonymous
Tire Wall
Start by reading the codes yourself. It's easy. Links in my sig.
