Check engine light
farley556
Louisville, Kentucky
My check engine flashes on and off when i accelerate. It seems to happened more when engine gets hot (thats when it shifts like **** as well), But it happens when i take off slow and fast, and it also does it when i drop upper gears and get on it a little. Any ideas?
Please see the link in my signature and check the codes. It only takes a short jumper and the ignition key. If you see the CHECK ENGINE light illuminate, there is something wrong with the engine control system and the engine computer is trying to tell you about it. Let it. Read the codes.
farley556
check engine
I just ran that all those test. My buddy has a tester. But the light doesnt come on when i rev it up in park. But the results had nothing wrong. it didnt read anything. We didnt check all the wires though.
projectSHO89
SHOless In St L
If the CEL came on, the computer should have stored the relevent code(s).
Go run a KOEO PCM Quick Test.
Steve
91 SHOplus
Sholess 4 Now
North Jersey
You don't need a tester, just a paper clip. The hardest thing about pulling codes was getting the damn "eec-IV test here" plastic cover off!
