Cheapest good 02 sensor replacement, and do I need thermostat housing?
SHOblime
State College, PA
Hey I need the cheapest good 02 sensor replacement. I believe it's a bosch part for like $35? I need two, I have an '89 (MTX). I also need to replace my thermostat, should I replace the housing, or just the thermostat? Also does anyone have a diagram of where the thermostat is located? Thanks a lot!
marvsho17
Joshua S.
rockford, il
Unless you've got a coupon, 35 bucks each is about right. For the thermostat the housing does not need to be replaced. Just pop the new one in there with the jiggle valve at 12 oclock. To find the thermostat follow the upper coolant hose from the radiator, it's just under the throttle body.
SASHO91
Zoom Zoom
San Antonio,TX
If you cant find one with a Jiggle valve, (i couldnt) drill a small hole on the edge, and put it at 12 o'clock.. :thumb:
DHMag
Free At Last
InCahoots, Texas
but remember, the t-stat only fits one way :) offset bypass valve.
Be aware that you must transfer the rubber gasket to the new thermostat. That is the only means of sealing that the SHO's 'stat uses.
Saleen SHO said:
If you cant find one with a Jiggle valve, (i couldn't) drill a small hole on the edge, and put it at 12 o'clock.. :thumb:
I've done this. But have come to the conclusion a properly sealed NON-LEAKING system with a KNOW GOOD radiator cap is of the up most importance.
