cheao thermometers
1slickRED89
Guest
Toledo Ohio
the furnace in my workshop won't light last week, so i bought a new thermocouple (T/c for short). that got me thinking (where i often get in trouble) T/c's sell for $60 in EGT and industrial applications, why not use a !!! $3.99 !!! T /c from ace hardware.
so i made a genuine/industrial grade T/c from K type thermocouple wire and did a little comparo. in an ice bath (used frozen sandwich meat) the Wire T/c read -6 C and the Ace T/c read 10 C. then i lit up a lighter and the wire T/c read 1100 C and the Ace T/c read about 800C. now, 16 C down low and 300 C up top may seem like alot, but it's better than guessing, or not knowing. plus the wire T/c has much less mass and is easier to hold at high or lower temps. on a car where heat is more abundant than some corn beef and a Bic i would think they would read much closer.
the real advantage here is that one could install these all over the place and get relative temperatures with decent accuracy. not spending $*** on T/c, and replacing them as they fail for less denaro too. just grab something like this readout (~$100) and one would be all set.
1slickRED89
Guest
Toledo Ohio
to try this idea on a car I purchased a Lab grade K-type handheld readout, (Cole Parmer) for less than $20 off of ebay. can't wait to see how it goes.
Get yourself some RTD platinum sensor wire and you can put the sensor about anywhere. (If you can afford it) Just cut to length and crimp a bare electrical terminal to the end, then fasten as you want.
It's pretty simple. They use two wires of different metals. There is a precise change in resistance with minute temperature changes at the point the two wires meet. We use crimp on connectors at work then just put them under a bolt head. Or you could just twist the wire together and immerse it in a fluid. There are probably a 100 different probe forms available.
1slickRED89
Guest
Toledo Ohio
ok, sounds like they are alot like T/c's as they can be made with bulk wire. but since i already have an investment in thermocouples, small as it is, i'm just going to stick with that.
I know that most temperature reading sensors on a car are of this type (ect iat), so they must be well suited to the automotive enviroment.
