Changing the VSS on a 94 ATX
WILL SHO U
Sooner or later
Home of the Indy 500
Ive searched found numerous threads, but no definite answer. Where is the vehicle speed sensor and how do I change it on a 94 ATX. Any help is greatly appreciated.
projectSHO89
SHOless In St L
There was a thread with this EXACT information in just the last week.
You should be able to find it in a minute or two.
Steve
shogen2
omaha,NE offutt A.F.B
i wrote a write up last week about me replacing my vss but here's some quick info for you it's not that hard just make sure to let the motor cool overnight your hands will thank you.
Yeah it's not bad to replace if you can get your y-pipe bolts out it depends on how rusted they are, if they do break it's no a big deal just simple hardware nuts and bolts will fix it.
The best thing to do make sure to spray the bolts down with the rust breaker before you start after that just remove the y-pipe bolts.
theres 2 for the front ****** 2 for the back and 2 where the y-pipe meets to the rest of the exhaust they should be 14mm nuts after that remove the heat shield from the vss housing unplug the vss electrical connector and then pull the pill holding the speedo cable in and then remove the 10mm bolt holding the vss sensor in place and remove the sensor swap over the spedoo gear off the old vss and repeat the procedure it took me about 2 hours but it would have taken less if i jacked up the car and let the motor cool over night.
shogen2
oh and just so you know since i think i forgot to post it the vss senor is on top of the transmission on the passenger side right under the back exhaust manifold and behind the y-pipe.
once the y-pipe is removed you will be able to see it really well since there really nothing else back there on top of the trans, but i just wanted to add where it was.
