central missouri repair on shift linkage
missouri89sho
Missouri
My 89 shift linkage broke while on trip to K.C. Small black plastic grommet at left bottom of shifter stick. Ford dealer there put a glob of solder to hold things together so I could drive it home. Local Ford dealer can't find parts. Maybe this is the time to install a rod shifter? Any tips on where to go in St. Louis or Columbia?
ckinney89sho
fo SHO
NY
I had the same problem. What I did was took it all out then drilled the ball out on the shifter, then put a nut, bolt and a metal sleeve over the bolt so there was less play in it.
I think it works better than factory. It only took about an hour.
operdot
USA
X2
I did this to mine, also did the same thing on the transmission connection side. The shifter feels better than any of the rodshifter cars I've driven. :thumb:
