CE light
SHOPhear95
south SHOre mass
Why does my CE light come on only when I drive on the highway? my cars usually starts to run like crap and eats gas quicker. but it never comes on when driving normally around town
matt
1995 ATX
Custom 3in catback with Vortech mufflers
Intrax lowering springs
Sho-Shop lpm
Sho-Shop CAI
B&M Trick Shift Synthetic ATX FLUID
Mille Miglia Action with 245/45/17's pirelli p7000's Supersports
60k service and 3.0 intake cams coming to a SHO near you!
Two Yamaha powered Intrax stickers
Objects in the mirror are slower than my car!
"Attention passengers, we seem to be experiencing some Godzilla related turbulence. just sit back and relax, when we reach 30,000 feet he usually lets go"
S
slosho
Guest
Pull the codes and find out why the light is illuminating. My guess is the O2 sensors.
95' ATX Silver Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a few "PCV" lines
Lighting mods
Convinience mods
More to come.
By showing you the CE light, your car is trying to tell you what is wrong. Listen to it. Read the codes. Make a 4" piece of wire with a 1/4" spade lugs on each end. Then go to the SHOtimes links I have posted so many times. With the jumper wire in hand, it takes less than 2 minutes to check the codes.
A failed O2 sensor sounds like the most likey culprit, but let the codes confirm the problem and tell you if it the front (left) or rear (right) bank sensor.
Scott
1991, 253K miles, glass hood, police grill, SVO shifter, Catz fogs,
SHOPhear95
south SHOre mass
Thanks guys. I was assuming it was an 02 sensor or two but wanted to get an opinion from the pros.
matt
1995 ATX
Sho-Shop lpm
Sho-Shop CAI
It's fast as F#%&!!
