Ccvs
Lupo
Huntington Beach, CA
Not quite sure how well that would work on a boosted SHO.
It has been my experience that you should never block either port; crankcase or valve cover. At one time I blocked the crankcase port (with check valve) and put a breather on the valve cover. Under boost, it would shoot oil out the valve cover breather.
Both the ports have to be evacuated during WOT in my experience.
yamahaSHO
E85 whore
Arkansas
I agree with Lupo.
I don't see how it would ever build vacuum on our setup. I've run something similar and ended up with a failed check valve and blown rear main seal. Terry ended up with about the same.
