hypnotic
I have a 93mtx and I have recently gone through my third ccrm. The first one was replaced from the previous owner in 2003 and then I got one from a junk yard then discount auto. The problem that I am having is symptoms similiar to a bad CPS. I have changed that. But what keeps happening is there is only one wire going bad on the module, that is the power going out of the box that powers the fuel injectors and the MAF and coil I believe. Each time, the car bucks and the check engine light goes on and off and then it stalls and dies. All I have to do is splice a wire into the red, power going out, wire and connect it to the positive battery terminal. It will then start and run.
I believe that there is something that is drawing to much power from the module. It only messes up the one wire and every other wire works and has the right wattage coming in and out of the module. I have looked at the schematics to figure out why it didnt start the first time.
Any help would be great and I couldnt find anything like this any where else on the forum.
thanks. craig.
thanks. craig.
