Started the my 3.2. Started easily after enough gas in tank. It acts like high in timing. [slow/draggy starter, belch thru intake once, no throttle response] I know how to set timing in a distributor type. What can cause this in the 3.2? I ran it 3 times for 30sec or less. Only thing I found after shutdown is fuel on top of fuel regulator. So going to replace it next time. [ dark outside now] Could that be a issues? definitely fixing it.
Any idea's, wiring issues. Didn't run long unknown if can pull codes. Thanks all. Maurice
Some info. Motor out of a 94, Now in a 93 Mustang converted to RWD. I did install new timing belt. Lined up the marks as marked on belt and instruction in repair manual. Could I somehow get that wrong?
