smp321_98
Hello All... I just bought a 94 SHO (my second SHO), I bought it with some problems in hopes of fixing them... Well here are the problem(s)... The engine runs rough almost seems as if it is skipping; second it does not have much power, you can floor it and it sill wont move; third I get a smell of gas inside the car when I floor it and lastly I have oil in the sparkplug groves (which I already read about in this forum) ..
This is what I have done so far: I’ve checked the timing belt.. is nice and tight and looks good. I've pressure tested all the cylinders, 4 were 240psi, one 255 psi and the last one was 235psi. Any thoughts on those numbers, as I don’t know what is good and what isn’t? Also, as the car was running we noticed that the CATS were bright RED!! Now I know I could get all these problems with a clogged Cat… only thing I don’t know is how to test and see if the cats are in fact clogged. Any suggestions as to how to check the cats or what might be causing the cats to turn bright red??? Any input would greatly be appreciated!!! Thanks…
Sam
Sam
