Car Stalls, Throws codes.
CademiaX
What's an SHO?
Utah
Well, I was starting to feel left out, over a year with no CEL.
So I was driving along and I go over a speed ****, not a bump. I have the clutch in and I'm slowing down, as soon as the rear tires come down off the **** the rpm's dip down to about 400-500RPM and the oil light(the red one) flutters and she dies. So I try to start it back up and its flooded, so I just put the pedal to the floor and fire it up, works like charm, drive it about a mile to a parking lot with no issues. Pulled the maf sensor and took off. Pull out to the light and she dies, fires back up just fine. This has happened a few times now and the check engine light popped on the first time around.
I don't have any performance loss at all. Just when you let it idle, SOMETIMES it will die.
111 System checks OK - System check good
157 (R,M) Mass Air Flow signal is/was low or grounded - MAF
- unplugged the maf sensor
528 (M) System shows voltage at pin 10 (is A/C on ?) or pin 30 (PNP, CPP switch) - PNP - a/c on while testing?
542 (O,M) Fuel pump open, bad ground or always on - - Power / Fuel Pump Circuits
- car stalled
at least I got two good codes :)
Anyways, the one code is from me pulling the maf and ther other is system check all good. 528 confuses me, the A/C was off, fans off. 542 seems to stem from the voltage issue and causing the fuel pump to crap out.
I also just had my exhaust tack welded to hold everything in place. Before that the rod bearings. Honestly everything was great after the rod bearings, just an exhaust leak that I had fix and then had everything tacked, left there and thats when the problems started.
shotime1994
AirHammerAndrew
New York
If you have the a/c on while pulling codes you will get 528. You get code 542 because the car stalls.
CademiaX
What's an SHO?
Utah
A/C is off for sure.
The reminds me, I sometimes hear a damn clicking sound behind the dash, possibly related to the A/C? Maybe the computer thinks its always on? The compressor isn't kicking on or anything. I think its the blend door tho. Everything will still function when I hear the clicking, just won't get cold air until it stops.
So, not even one of those codes points to a problem?
shotime1994
AirHammerAndrew
New York
If you turn the a/c on does the fan come on? Im talking about the engine fan.
CademiaX
What's an SHO?
Utah
Just went and tried, but it didn't come on. The fan does come on, it was kicking on when I pulled the maf and you can hear it during the KOEO. I have no problem with heat while driving with the A/C on.
Well, that's odd, the codes are gone now(Check engine light is off).
Possible intermittent ccrm issue?
CademiaX
What's an SHO?
Utah
Not sure, but I just went for a drive and not a single problem... hmmm..
I will have to grab one tomorrow and drop it in if the problem happens again.
well, guess I will posted in the wanted section, $85 + $40 premium for the 94-95 on shosource. Why do I always feel so ripped off on some of the parts there? Hit the drop down and BAM! A for $40 price hike for the 94-95. Was going to shell out the $85 to buy it too. BS, thats what it is!
Huntervf
Bored now
Back in Michigan ... again.
My 93 ATX would sometimes do that. Never did find the specific problem, though I did eventually develop a stumble/loss of power that ended up being a failing MAF. Since replacing the MAF my low idle/stumble hasn't come back, and that was about 2 years ago. I should note that cleaning the MAF didn't help; the sensor itself was bad.
CademiaX
What's an SHO?
Utah
I suspect this is maf related, I left the maf unplugged for the rest of the day. When I plugged it back in and went for a drive everything was fine.
I'm going to pay attention to the fan if it happens again, but I am pretty sure it was one last time it died.
