94shobuildup
I just bgoutht this car about 3 days ago, and i am a new owner to a SHO, well on my way to work this morning the engine light came on and the car started bucking, and after a bit it stalled, i got it started back up but it was running real bad couldn't get the rpm over 4000 really, and whenever i pushed in the cluth and let off the gas it would stall. It also went threw a lot of gas, and smelled it too. A few times it stalled it didn't want to restart but after about 5 minutes of starting it would finally start but run real bad. I am a little nervous being a new owner that there might be a bad problem, but after looking around seems it must be something stupid. This car has had modifications done, inclucing a superchip which doesn't even seem to make a difference, and a bigger maf, not sure what size by PRO-Maf. I did some searching threw shotimes, but didn'treally have any luck. I am going to try and check some connectors, and clean battery terminals, but any suggestions would be appreciated.. Thanks Jeff
