Can't get engine to start
1993TaurusSHO
Today i went to go start my 93 Sho and I turned the key on and all the lights come on fine but when i turn the key to start it nothing happens.I can hear a faint clicking coming from the engine and I know it is not the battery does anyone have any ideas.
93nighthawk
Mitchell, SD
If your engine is not turning over, I would say it is definitely your starter, a pretty easy DIY. The clicking noise was the starter solinoid gone bad. It is all one item so you have to replace the unit.
If your engine is turning over and not firing, I would say it is the Cranks Sensor (if the tach is not moving), or the DIS, coil, ground.
