SHO_ROLLER_2
Well-Known Member
This has been driving me nuts and I can't seem to find the problem. Lets say I'm backing up, I hear a light "Cluck" like something just settled. Then, I'll start to go in 1st gear, and USUALLY by second, I hear it again. I can feel it a little, but not much.
The small trans strut on the drivers side is SHOT! Moves up and down freely. Could something this small be causing it??
I checked the mounts and the front is fine. Under load in reverse, the rear will rise about 2 1/2 inches.
What gets me is that it does it in reverse gear, forward gears, sometimes as I downshift, and in the middle of traffic. It isn't violent, just really annoying knowing something is loose/busted and I can't find it!
Thank you for any input!:wave:
Edit: Ignore the Solid MM's in the sig. Turns out, they never got put on
and have since VANISHED!
