Can some one give me an clue
goalieman59
Learning Slowly
OFallon, IL
I need to replace my starter, I have a parts cars but I really dont know where the starter is can someone give me a idea. I thought is was just to the right of the oil filter. But i just wanted to make sure. Thanks
goalieman59
Learning Slowly
OFallon, IL
My car died the other night and she is sitting in the drive way right know waiting on me right now.
SinisterSHO
Rust free
630, IL
crawl under the car and look up. should be on the front of the block right under the oil filter. I believe its 3 bolts and a couple connections. pretty straight forward.
goalieman59
Learning Slowly
OFallon, IL
I needed all the help i could get cause I don't work on my car often, i am a computer geek instead.
Storm-Chaser
Shit Louis
You'll need 13mm and 15mm sockets, possibly an 8mm socket depending on how the small wire to the solenoid is attached (usually it is a single-wire slip-on connector).
The lowest bolt on the transmission housing is 13mm if I remember correctly. The top bolt, is a studded 13mm hex head, with a 15mm nut on top to retain the large ground wire. The 15mm nut sits close to the transmission housing, so a thick-walled socket won't work. I find a 3/8" drive socket works, with a 3" extension so the ratchet-head does not hit the transmission housing.
The largest wire to the starter solenoid is held in place by a 13mm washer-nut, if it is the original. A ratcheting wrench works best for this one.
goalieman59
Learning Slowly
OFallon, IL
Thanks for all the help i got the parts cars one off last night I will taking it tonight to have it tested.
hawkeye18
Sorta cares
Norfolk, VA
Being a computer geek is no excuse. I'm quite the computer geek as well, and I do all the maintenance on my cars. Nuts and bolts aren't any different than screws and molex connectors! It's just a little more messy, that's all. Cutting your knuckles on a crescent wrench isn't any different than slicing your fingers on a Zalman CNPS9700!
goalieman59
Learning Slowly
OFallon, IL
True the darn case are sharp in areas, i guess i just need to dive in and see what happens. I guess if I break it someone can always help me fix it.
johndallara
Chapel Hill, NC
starter replacement
call or PM me if you have any questions, I can post some pics if you need them. My 95 ATX is up on jacks currently, so pics of the starter location are no problem.
I agree this is a fairly simple replacement with a few basic mechanics tools and two jackstands.
be sure to disconnect the neg battery cable first.
here are a few links which may help.
http://www.autozone.com/addVehicleId,1982304/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c1528006310b
Not totally specific for the SHO, but good info on how much to torque the bolts, etc.
http://www.autozone.com/addVehicleId,1982304/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c15280062f5c
Best of luck.
JD
