can I see some pics of turbo'd SHO's?
SinisterSHO
Rust free
630, IL
MYSHO1 said:
Bittersweetsho, SHOULD be dyno'd this Tues... Pics and numbers will be up ASAP
I certianly notice alot of talk about this car from everyone except the owner.
SHO--ripper
928 Euro
winsted,CT
Sinister what do you want me to say? Mabye that i have 44lb injectors, a garret T04 with a .60 A/R, 80mm maf pull through, external wastegate, 3in exhaust, and a 70 shot of the giggle? I want to get some dyno #'s before i post another i got my turbo SHO going thread. Don't worry sinister you'll :hail: :p
SHO Continental
Moderator
Northridge, Cali
focus'N'SHO said:
yeah since I posted this I found out the t-bird turbo would be too small.
What if you ran twin turbos? if one of those runs 2.3 liters, then 2 can run 3 liters.. right? :shrug:
the possibilities are endless.. ;)
MerkXRTurbo
Vancouver, WA
Yes, however it depends on which turbo you are running. The 87/88 Turbocoupe had the IHI turbo, which is too small for even the 2.3. The Merkur, Mustang SVO, and earlier Turbocoupes have the T3. This would be a better match, however it's still a little too small for the SHO, IMO. After doing some simple math for turbo sizing recently, I found out that 3 cylinders in one SHO head outflow all 4 cylinders in the 2.3, so even in a TT setup it should be able to support a larger turbo than the 4 banger can.
1slickRED89
Guest
Toledo Ohio
yeah since I posted this I found out the t-bird turbo would be too small. So that sucks I guess I"ll have to look around or just buy a new one and spend a bit more. I"m thinking a GT28RS would work well for a quick spool and descent power level.
that sounds good. you'd be doing yourself a favor. I can say that things can get pretty complicated under the hood and atleast for me, it's nice to know everything is functioning, new and properly spec'ed/sized/engineered. some new parts have warranties too!
the way I see it, I don't want to drive down the road worrying about oil seals, old/used fuel injectors or whatever else used part may/will fail. it's bad enough to drive a 14+ year old Taurus to begin with.
MerkXRTurbo
Vancouver, WA
I've always hated the idea of remote mount turbos. What'll happen when that 1000 degree turbo gets splashed time and time again in puddles?
ALWyzBrknSHO
Springfield, MO
It actually doesn't run nearly as hot as a turbo thats right off the exhaust manifold so it's not as big a problem as you would imagine.
1slickRED89
Guest
Toledo Ohio
don't look under a Porsche, or a F1 car. many full-effort turbo cars have low mounted turbos that can and do get hit with cold road water spray. then again, I would not forge a river in a low mounted T-setup though.
focus'N'SHO
Summitville, IN
yeah I know your point, but also I"m very much a budget modifier. If you look at my sig and see the mods on my focus.....all power and handling mods I only have $600 in them. Until I get a better job I've gotta scrimp and save for any descent parts. So I'm used to buying or using used perf parts. In fact all of my perf parts on the focus are used or custom made.
The SHO is my second car, so if I have a prob and break down Ive got something else to drive that is dependable unless I blow it up with nitrous. ;)
SonicRiot
Handbanana!
CT
I wouldn't worry about the turbos weathering road conditions on a remote setup as much as I'd worry about the weight of the 3 miles of piping neccessary to make it happen!
SHOSIG
Is that right!
OH you didn't know
Anyone know where I can get a deal on 3 miles of piping? OOOPs...I need 6 miles for the twin remote setup :nut: .
UnderPSI
Utah
SHOSIG said:
http://www.supermotors.org/getfile/250634/fullsize/DSC01906.JPG
Pair of T3's(chrysler/dodge) on a 5.0 mustang. Remote mount too. Good info on this site also.
That kid lives in Tennesse, I talked to him a few times when he was putting it all together. Helped him with some ideas on it. There is a complete buildup thread on Turbomustangs.com of that car. Works very well. It is a 95 5.0, with H/C/I, I beleive.
Here is the link, http://www.turbomustangs.com/smf/index.php?topic=45570.0
UnderPSI
Utah
LeddZepp8687 said:
Is it safe to run a small turbo running like 5 PSI on a stock motor???
Size isn't the issue, 5lbs of boost is safe for 9:1.
TT SHO PROJECT
OHIO
im running a 16g at 8psi most of the time. had it upto 10.5 with out a problem and this is a non-ic setup. bone stock engine fuel system and all. 9.8:1 c/r so 5psi wont be a problem at all. and sure size does matter... 5psi from a 100mm turbo would be like lets just say 1100cfm of air..... do you have the fuel system to feed that much air? hehe or if you have lets say a t3 at 5psi your pushing lets say 300cfm of air. much less fuel is needed :p sorry just thought id throw in my $0.02 this is just an example theres no real facts with the numbers i used.
