One more thing, buy an electric gauge for your oil pressure. I was gonna get a cheapie mechanical setup but everyone and their mother suggested that I get electrical...
JCWhitney has a selection of electrical water temp, oil presure and volts gauges that are under $20 each with the sender and proper adapters you need. The oil pressure gauge is a little scary to look at though since it REALLY wags around when you're speeding up and slowing down.. I'm sure better (autometer, vdo) gauges aren't as jumpy and are probably more accurate to boot.
If I recall correctly, the water sender is 1/8" NPT and the oil presure is 1/4" NPT (By the way, that doesn't mean the diameter of the opening, it's the pitch of the threads or something. The oil pressure hole is like 3/4" wide..)
Jeff
<small>[ May 22, 2002, 11:32 AM: Message edited by: jcostantino ]</small>
