I removed the driveline from the Shogun last week and pulled this clutch out. Can anyone possibly identify what brand/model it is, and/or the flywheel? The pressure plate is a cast steel, not a stamped steel unit like on most cars.
The clutch pedal pressure in this car is a bit abusive. it could be a bad match up between the master and slave cylinder bore diameters(this car is hydraulic converted), but if I can identify this clutch I may be able to factor in the PP spring pressure to determine what I change. The car is supercharged with what appears to be an old V2 Sho Shop kit from it's former owner many years ago. I am retaining the SC setup for what it's worth with many changes to be made, but don't necessarily want nor need an overbearingly heavy clutch.
My ap
ologies for the thumbnails
My ap
