can anybody help me please
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
hello guys,
i am in big trouble,
well when i got back home today around 3 pm i decided to replace my front brake pads and the sway bar links.. i already replaced the pads and had no trouble at all it took 10 minutes per axle. however though n ow i ve been seating since then wrestling back and forth with the sway bar link in the driver side ... i broke it off and losened the top bolt off but the bottom bolt and nut wouldnt losen so what i did i took the sawzall and cut bnoth sides even with the lips of the sway bar so now the whole is blockes still with the metal piecve that is held there.. please help me how to get that thing out.. i dont have anyplace where to grab it with pliers or vicecrips because both sides are cut even and neat flush with the sway bar metal... any advices please let me know
thanks
endri:thumb:
Mr Anonymous
Tire Wall
A hammer and a punch or drift should work, the Sawzall shouldn't have heated the metals up enough to really weld them together. An air hammer would work perfectly if you have access to one.
Endri_SHO
SE 300 , S 500
SASHO91 said:
did you put new rotors on? or turn the old ones? New pads on old rotors= :nono:
YES THATS WHAT I DID , WELL WHAT YOU MEAN TURN ROTORS?>? I NEVER HAVE DONE THAT MAN, EXCEPT ONLY REPLACING THEM WITH NEW ONES..
SASHO91
Zoom Zoom
San Antonio,TX
turning would be cutting the rotors down a few thousandths to get the rotor true(straight).....
pimp
Orange County NY
what the deal is on the brke deal is that if you just replace the pads with out replacen the rotors or haven em cut by a shop, witch is not recomended on frt drive cars, the pads them selves will diminish a whole lot faster, and orcasuse even more vibration up front causing more warping and possbl trouble soon with ur calipers also.whhen u do it do pads and rotors even if ya have the rotors cut, you give hem a smooth surface to grip on.and if ya know this dont mind me, its just some advice that anyone can take or leave, i know alot of ya know this already so just for the ones who dont.
