JRA2000TL
The Complainer
I did a search but didn't find any details on my specific question. I have a good replacement camshaft sitting in my bedroom floor that I want to install on my 90 since the lobe on #4 cyl is pitted/damaged (upper/intake cam) and has a damaged shim. I have practiced removing this stuff at the junkyard but I got stuck on the end where the woodruff key is (that big gear that the timing belt goes over). I rounded off one of the 3 bolts (on the j/y car-not minie) on the gear and could not figure out how to get the cam loose from that end (where that sheild thing is behind the gear). I guess I need to buy a cam seal and install it too. I hear that's a PITA. I'm not doing all 3 seals...car leaks very little oil if any.
I've figured out how to take just about everything else off to get to it. Any special procedure I need to go through so I don't strip out bolts or break anything?
