camber?
97V8SHO
V8's Own ALL!
Oklahoma
So does anyone know?
Paul, I read that page but it only explianed what I already knew unless I missed somethin.
If you move the plates out then you are moving the top of the tire out in relation to the bottom. This is moving towards a more positive angle.
Camber2
Camber – What is it?
Camber is the inclination of the wheel from the vertical when viewed from the front. When the top of the wheel leans out you have positive camber, lean in equal’s negative camber.
DraGGin2k
Michigan
Here's a pic of my truck....that's an example of extreme NEGATIVE camber. (Top of both front wheels tilted inward toward engine.)
Of course the camber corrects when I air the truck up
