Best Sho
Can anybody tell the torx settings for the bolts & nuts, for the water pump, crank, cam gears, timing belt tensioner, cps, etc, etc?
Water Pump Retaining Bolts 12-17 lb/ft
Water Pump Pulley Bolt 12-17 lb/ft
cam sprocket bolts 15-18 lb/ft
timing belt tensioner locknut for mtx only 24-38 lb/ft
timing belt tensioner 3.2 or atx I guess 12-17 lb/ft
Timing belt tensioner idler pulley nut 27-37 lb/ft
cps 13-22
Timing Belt Cover 62-97 lb/INCHES
Crank Bolt 112-127 lb/ft
Engine Support Dampner bolts/nuts 40-55 lb/ft
idler pulley nuts 24-36 lbs/ft
Intake Manifold Retaining and support bolts 11-17 lb/ft
Idler Pulley bracket bolts 11-17 lb/ft
spark plugs 15-22 lb/ft
upper accessory drive idler pulley bolt (3.2 only) 26-38 lb/ft
lower accessory drive idler pulley bolt (3.2 only) 27-41 lb/ft
Throttle body bolts and nuts 12-17 lb/ft
valve cover bolts 7-11 lb/ft but be very careful
If you need any others just ask
My dad just passed away, and it the only car I have.
Please somebody.....
Sorry to hear about your dad. I've only really started to deal with deaths last year. Atleast 5 people died that I knew of. It was quite scarey and upsetting especially when my mother's brother died leaving his 2 boys without parents because their mother is brain dead due to alcoholism, 5 years in a coma, and hospital neglect.
If you need any more numbers or advice just let us know. I tried to think back on 60k and give you all the numbers you would need, but I may have missed a few. I can't stress how important it is to be careful with the valve cover bolts. I snapped 2 the other day with my torque wrench. I think it's out of calibration due to others misuse of my tool, but I know the bolts are fragile to begin with. Good luck.
