Cam Seals
Best Sho
Hudson Falls, NY
Does anybody know where to get the tools to remove and put back on the seals?
And where can I get the torx settings....
I'm doing the water pump, cps, crank seal, cam seals, etc.?
Thanks, Mike
And I now know how to put my pics up here, so Thanks!
Does anybody know any SHO mechanic type people up here in NY? Glens Falls, NY.
Most folks drill a small hole in the seal, insert a sheet metal screw and pull with pliers. The back bank exhaust cam seal is tough to access and it would help to have a Dremel tool and/or flexible drill extension.
MTX or ATX? I have a pdf procedure for the MTX timing belt, but you should be using a shop manual. Doing this job wihtout one is almost a guarantee of something not done properly and that is much more expensive than buying even the Chilton's manual.
Best Sho
Hudson Falls, NY
Hello,
I joined PhotoIsland, but didn't see a spot to mention your name. Where would that be and I will.
Are the blue arrows the cam seals?
Are the red arrows the camshaft?
The back arrow cam is leaking. The front ok. And I don't know about the 3rd. Where would that be??
Can I replace just the leaking one? Or all 3 or ?
Thanks you've been a great deal of help to me and others as I see in the post. So THANK YOU!
Mike thumb hail finger
<small>[ May 02, 2003, 05:22 PM: Message edited by: Best Sho ]</small>
haydenm315
Reisterstown, MD.
Best Sho:
Thanks, Mike
Do like Sdpatt said to remove the seals. You can also puncture it with a flathead screwdriver and pry it out. I'm pretty much a newbie as well. My friend and I were dumbfounded for atleast 30 minutes when trying to do the front crank seal, which is very similar. You definately don't need a cam seal installer tool like the helms shop manual says. Just make sure you put them in the same way they came out. The lips should be facing inside the valve cover. As for which seals to replace, it all depends on how old your car is, how much you want to pay for seals, and how much time you want to spend replacing all the seals. I upgraded camshafts, so I did all of the seals at once. It's entirely up to you. Those seals are pretty good in my opinion. I haven't seen one leak on my car yet, and they're all over the place.
Best Sho
Hudson Falls, NY
Hello,
Can anybody tell the torx settings for the bolts & nuts, for the water pump, crank, cam gears, timing belt tensioner, cps, etc, etc?
Or least if there a site that might list them.
I don't a manuel at this time of access to one.
I need to get it back together.
My dad just passed away, and it the only car I have.
Please somebody.....
Thanks, Mike cry
93 3.2 112,000 Green, Stock
<small>[ May 04, 2003, 04:29 AM: Message edited by: Best Sho ]</small>
haydenm315
Reisterstown, MD.
Best Sho
Water Pump Retaining Bolts 12-17 lb/ft
Water Pump Pulley Bolt 12-17 lb/ft
cam sprocket bolts 15-18 lb/ft
timing belt tensioner locknut for mtx only 24-38 lb/ft
timing belt tensioner 3.2 or atx I guess 12-17 lb/ft
Timing belt tensioner idler pulley nut 27-37 lb/ft
cps 13-22
Timing Belt Cover 62-97 lb/INCHES
Crank Bolt 112-127 lb/ft
Engine Support Dampner bolts/nuts 40-55 lb/ft
idler pulley nuts 24-36 lbs/ft
Intake Manifold Retaining and support bolts 11-17 lb/ft
Idler Pulley bracket bolts 11-17 lb/ft
spark plugs 15-22 lb/ft
upper accessory drive idler pulley bolt (3.2 only) 26-38 lb/ft
lower accessory drive idler pulley bolt (3.2 only) 27-41 lb/ft
Throttle body bolts and nuts 12-17 lb/ft
valve cover bolts 7-11 lb/ft but be very careful
If you need any others just ask
Sorry to hear about your dad. I've only really started to deal with deaths last year. Atleast 5 people died that I knew of. It was quite scarey and upsetting especially when my mother's brother died leaving his 2 boys without parents because their mother is brain dead due to alcoholism, 5 years in a coma, and hospital neglect.
If you need any more numbers or advice just let us know. I tried to think back on 60k and give you all the numbers you would need, but I may have missed a few. I can't stress how important it is to be careful with the valve cover bolts. I snapped 2 the other day with my torque wrench. I think it's out of calibration due to others misuse of my tool, but I know the bolts are fragile to begin with. Good luck.
