Cam seal
DavidT
TN
well, I noticed the cam seal where the cam sensor is, has a good little leak. I did a search on it. Apparently there are 3 cam seals. If the other 2 were leaking, wouldn't they get oil all over the timing belt?
How hard is it to change the seal where the sensor is?
Also, where is the cheapest I can find:
a cam seal and
the oil pan gasket.
If the inner cam seals leak, the oil runs down the front of the block inside the inner timing belt cover, finally exiting as if it were a front main or front oil pan gasket leak. You can't actually tell that the inner seals are leaking until the inner timing cover is removed.
The cam seals come in a set of 3 (FelPro). I got mine from RockAuto with a bunch of other stuff. Part # TCS45870 $14.77 plus shipping.
The seal replacement is a really fun job. Do a search on "cam seal" and my user # 1084. I related some of the fun I had with this project in a post in early June or late May.
<small>[ November 04, 2002, 07:59 AM: Message edited by: projectSHO89 ]</small>
bmytych
