ISHOU,
With so many folks experiencing the same problem I'll post the electrical tests for the DIS (distributorless ignition) EEC-IV.
Check all grounds for good clean tight connections. The DIS module is mounted to the intake manifold crossover tube on the passenger side of the car.
The four small screws that hold it to the manifold are its ground, and the two bolts that hold the crossover tube to the heads also are "grounds".
Anti-sieze compound or "Kopper Shield applied to the threads help, and improve the electrical contact. Remove paint from the manifold under the bolt heads to insure contact.
Test 1. PIP (or Crankshaft Position Sensor or CKP)(Profile Ignition Pickup) to control unit.
Connect DMM (Digital Multimeter) or LED (Light Emiting Diode) test light between the PIP wire (Dark Blue) and the negative battery terminal.
CRANK ENGINE (Have the mechanics "lovely assistant do the "cranking"
You should get 3 to 7 volts or the LED light blinks. If not, the crank sensor, or the crank sensor power, or ground, or wiring (including the connection) is faulty.
Test 2. SPOUT (Spark output of the Electronic Control Unit) to DIS Module.
PIP signal OK, Connect DMM or LED test light between SPOUT wire (Yellow/Light Green tracer)(tracer=stripe) and negative battery terminal.
CRANK ENGINE (remember the lovely assistant)
Results, 3 to 7 volts or test light blinks. If not, Control Unit or wiring faulty.
Test 3. IDM (Ignition Diagnostic Monitor) to control unit.
Connect DMM or LED test light between the IDM wire (Gray/Orange tracer) and the negative battery terminal.
Crank Engine. (You guessed it)
Results 3 to 7 volts or test light blinks.
If not, DIS module or wiring, or connection, faulty.
Test 4. CID at sensor
Connect test light (LED) between CID CS wire (Dark Green) and negative battery terminal
Crank Engine (Do it again "Honey")
Results, test light blinks.
If not, CID sensor or wiring faulty.
Test 5. COIL POWER (COIL PWR)
Connect LED test light between COIL PWR (VBAT) wire and negative battery terminal
PUT the KEY in the ON POSITION (No don't crank it, Honey, just put the key in the "On" position! Never mind I'll do it. Get me a cold one, please!)
Results, test light on.
If not, COIL PWR wiring faulty.
NOTE ignition ground wire is BK/O (black/orange stripe.
A code does not automatically mean a sensor is bad. It means that the computer is not, or did not, get the signal it is programmed to expect from the sensor.
It could be due to a faulty sensor, but it could also be due to a poor connection, a shorted or open wire, or a poor ground in the circuit. DO THE DIAGNOSTICS.
SDPATT and some others can come to quick conclusions because of their experience, and the knowledge stored in the micro processor they have between their ears. Until you get to that point, DO THE DIAGNOSTICS. doh
Hope this helps, rangerj thumb
