sho_bc
Dragonboater
so, where the shifter meets the tranny, there is a ball and socket type thing that keeps the shifter not-loose inside the car/lets you change gears. not very mechanical wording, but i just woke up. its happened before, and i'll take a photo in a little bit and post it up to show.
this is the 2nd time its popped off for no apparent reason (it only happens when my mum drives the car though....:type: ). is this fixable or not? or should i finally get around to installing the rod-shifter i have under my bed? or even fixable so that it won't happen again until i install the rod-shifter.
thanks!
http://www.alexlangley.com/IMG_2421.JPG
http://www.alexlangley.com/IMG_2422.JPG
http://www.alexlangley.com/IMG_2423.JPG
thanks!
perfect temp fix until i get some other things here to install along with the rod shifter.
my problem is at the transmission end, not the shifter end. *sigh*
