bypass crank sensor???
TL8apxrx7
Missoula, MT
is there a way to bypass or test the crank sensor without pulling my motor apart again to see if maybe I intstalled it wrong??
LJRuddy
Pop lock n drop
Poaceae fields
There is really one way to install it. The little clip part fits around the metal "lip" that is attached to the crank and behind the timing pulley. If you screwed the sensor to the block with the 2 small phillips screws, chances are that you installed it correctly.... Given the metal lip rotates into the C chaped part of the sensor.
1993MTXSHO
Its a Taurus...
Jersey
I dont think you can bypass it. to my knowledge you need that sensor for the engine to run:thumb:
SHOpoor
New Jersey
It really only mounts as described above, but did you gap the sensor? .030
If not it could still give you troubles.
LJRuddy
Pop lock n drop
Poaceae fields
:oogle: you gap those??? i just put one in and i have everything back together now... :cuss: :banghd: :shappens:
AREA 91
PA SHO SHOP
Area 91
Gapping the crank sensor help's to ensure that the CPS shutter wheel is centered in the slot of the sensor. If it's off too far, the first time you rotate the engine, the shutter wheel will hit the CPS sensor. You will then have to get back in there, and change the sensor again. Not fun.
