LookAtThatSHO
Who's SHO Daddy
SHOTimes.com quote:
"I've had this buzz/rattle coming from the clutch pedal area whenever I shift above 4000 rpm. I determined the culprit was the adjuster tension spring inside the pedal arm. Wrapping some dampening material around the spring fixed the problem. "
I'm having the same issue, what would someone recommend to use as dampening material?
