SHOpoor
The butterflies on my 93 MTX do not close. I've confirmed that the vacuum is good, and that they will close when I bypass the valve. I've swapped valves and confirmed that it is good. I checked voltage at the connector and I only have 5 volts at idle. My wife's ATX has 13+ volts at idle and her system is working correctly.
Does anyone know the circuitry for this system? What is the source of the voltage? and why would I only have 5 volts?
I REALLY need some help with this one.
Thanks
Thanks
