bumper rattle/coming off
T
ThatSHOkid
Guest
on the rear passenger side. i notice that right on the fender the bumper plastic is hanging off a little bit. how can i make it so it is right up against the fender and make no rattles liek it is supposed to do?
RStalveyARFF
too many shos
Georgetown, MA
the sides of the bumper slide on a tab on either side, and the rear of the bumper is secured to the frame by 3 bolts on each side. I would heat the bolts up with a torch, spray some water on them to cool them off, and then remove the bolts, remove the bumper(with a helper or two) and then reinstall it, making sure both tracks are located on the tabs.
T
ThatSHOkid
Guest
when u wanna do it? i will buy you lunch/dinner again
tinkerkathleen
